Stato
bigno72":ptrmabq3 ha detto:
La foto pare in salita ma e' in discesa.
Dietro al muretto rosso in fondo c'e' un pozzo che ha sempre avuto tantissima acqua (siamo in fondo a una piccola valle).
-uJrAKzBJJEkVyc89dTwM4dCXO06VYbnI0X_YZJbsisThp0KQ4ZM7H2IC5uj3jwwoHRhomJcpDcqIx7fAGNaak6utZTou7Rqo9ol3qmCk5UKVt9xRSP8gLyRTujyfCAIV7F0EPeC6b9MWuCqu-HQcrQbaHIMqAAuZYXFZPGt1HrygxRQI-peKxdBojW-Bl1y1TpnjIqbJFgB7TJwOF6-lOTv-puciezazjlgtsKSVCK52JZ5AEFNdRM0MuYh51gaOq8-gr7r_P3q-0g8z49AhpsLQy4wPkeyaj8FBmP3GuLzBznH5qibb1F3xBmXCPj8GbOf9yJ--DEzESm9Omt0gP8B4JweUkffO-sj19kBfjo8crJkV4wxkvKmMIKn9Vm4zzrTAirRukj0eCKfwngE0trM9qHF0CQfTs-4AHxF5NNhmoZfs5PIUbLnGmF9MSDyWWvsp7ynB3dKvzc0zBEt4DXZ-QNH9g4o5QaT0cWik9WL2RMk8f6RgvhgWczBhapa4OGvnyAKccimzrnpoCWucbEvUDKxcbO4gxC0RFXwYsBvGmQZ9WFWwKTp8q3kWAzfT-ygWmErCQLtixW6NHJQ4SmCvIsxnNWyYWEJFDouC0s-S5p39YZT2w0yoJWO5lT0-3sU9zDh39v6UQ7ciWh3lbu5JWfunLs=w523-h929-no
Ss3pUVyGCwJJ5636lSLvIg-FNxLYC2FVoPb-fpzpvmTCuhezak895A7I9QstCIMC4cah3VaL1KHCp0TJFPeZbZIDxKxSRGJzXPfeS2xaOyi9IOnhmbTh_8ty_jMIsVkA8TeBFi8JvgCGyQQvxJ-soHz8XcYuBvUfAtc2CttXHSyGYDONnsp1FWBXT0m1TgcDVue4n_aWWxwVYcLpOKxJAVLmMdmLLs9AeHHnXc6-CMz6OXJXdYOpAGNhlb91Apk_RaW5DWHpAUJcbYaZKAkBpQqF4306EHnEGpM9FMi_zOCguWPfZlTa2C3bSpRMthxi_-eU4j271IPlvbtC42YJXS60W1xHd4DzLy1xLYpr8eQJixe2DKnHX-gyLAbIzqmHmPlr1BVZu66q55SYjwfss8ePUVRe7FkQ2lXaPWov56WAzoYs6lzwar0nr4zZc2RIUmE75cnnKK6YxOOA2TxffsFvXmylKk-7gkYW7TI9hsNMLKWn-xiLpzHNdhvqkrYmTLM3VDmci9G2wSgjjI-nGnZvbINN4eZmhh0pPV3KHhGYIooBVeBO7O22ylbPHciXlwfMjmz_cfIrUeOzO-kx_bRXQz2-suDjh1ncJsMUDMX1McpEWJ1VfTr5f4SvXcgyaq0wh5Mjk9VWEPjH4PKGZhSctuLs0WE=w523-h929-no
_zHZHJtccAeCqKPYrb235hpb3tNfI18boYM-EIhcgI6v_uT3-E1vh4bv-f9qHXBcQeNZrc5FTvrrTIZeINUJ67C1dcCn12okTOETfNLAlS-QTWmTwFu9myeJAP3vsKtRa2eMdcv8cjxfi2ao0xi08RQwg9Ht5REfkxHpaYiIwgeEswG-V2E3nVGOidWN2jZ7FYKrKkefN-REku1lY4th6IOIzm4pZ6CyxiJ4sr5ihrojdU1LhbrOUIAukWiwPBR36mftlihCnlvoDIMf5vpIOXytQSuZVOHib85aLlnts8ng1nAtxZUUy8SKAPFaseFr-wHISPWqxsseydmiBRS8rU3TteuggCDE1oMaHsOMxR_cVPw7SfOpGT-pXG7IVK7OVfcNyr9KomOJsUU_sE8jYdQB4XX3yw2xNAWNLu5Jo2pYTgCN-UQS666Qd9UAD2fON0HMdZIER0IW5KRJIbuk1SpkLt_-a3tjH7TN61pmP56hIDIBh-VGHl3E-YnVZZC1ihJ4D6Rtrhb_mQtCohPV38v74SxlwPNH_dLVzN43KVFWI5ou0ZPWIbsPR3OLcUD974GlxPUPUTI5_J_mVvtolkKIOD_ZHJaJ-rnuKtn0lg2AngapA-0iir4ZASsHTnHToJRltTUwOg6Q3WvXb9uPbGCTPzCM4uA=w523-h929-no
mmYL3A_3-mjhWBctCC4N82-Yxl3MywRbap4Ne7JiHEGDY_QBtTVwLWBRMcNg8xezY0Vh2YZa5ENyNtITi74IsU1vsgD8BQcwcWIMGj0XYHa-AsuJkjD2RgmQlFHWe1lObL1GhAN2V76drsppbiMuywg1Tk2sLVAQAzrJOKkuVyyevA-AQ001g8AHHmzwZIN502KJzNzHgyYkFiYneutvcCcN87exkoBf0npMfD9W52kICGXhIZuIXPG9UyspCvIvSQhVlOyzpEbKcMSaAsXvPBUuGw1Zzy5c85NeQH5Kz1FokDywHXvwUFfhnn30nt-KpWhgeQ4GBw1QSjh-lYReZ9iq5PMtmfixUlUxMXUPv-n1FCKskvuzPBHB-NpeQ4Xza6Vh5Ie0G0w08fMsWEWzdAFygaitLXrM5DcaS3jOjZ6Ejg3LL85D8UsVDL_DSvFBt21wLAERH1hpLFegyyTvv0ok9hgcmoPEC7inboXWNVAV3bSH6IR4zWHXe5MRkCKnZwS-ksXsrgpOT8m8lk5WtG7Nw0NAPvPbr8vsBTkAPWBwDFbDtdeS9ykWvGKThYH49PEvtwI6Uyv442fMJIe5xELEqMkFTUyXr96CLGKjrVyPf6mfakjD4oAC-OQa1y0JFbIcsFsBD_SzyhOV8VdgECzSZO0sIGU=w523-h929-no
fC847L_q8jL5hmxkyt87-QC7Lv-5kLqxU779_XoDW5qw3EFleBzODqDqxo0ty8TdqQUYLst2fTYeB-tLFnYa-nqUiYN2hwjhTjLlgo38ufFVFeCGdyO0mkR3I8plhM3NgrzFy00R4oM24sWh7Xn28WUYxWTSBif5COqvWvgvsXJfWW7D5ofLQ9bKcGnWmNAA1E_Ho7ltL-ESqJD_qWSchmAwRx5SWV3Xg0T71yBckynRg3ApGoY_I6hcG1Cva-aEXdgZ0cuMUaab-nGt-18pJ0u7BnM--axZJpL9pYl_2ufGXdSYUygYDQW7jOPpROWpzA5BykrrcJw69azDLrXaMpOjRj8m4SNAEQr8SW9yQbXsyIZLJ2qRhnu1vpt98NNFb6SJdkv9LlnjXUycK_FdunD1wSmupTcLQy8VuyQ-LY3Jg-r8gYsPg5hT5zRpn9-_9qoitllHaFn887lAHWtuOVFiw480WquFEyTgMXx3Wd38OkXtJPMDwY3sP7l3gsU3ogMY5iNRtShU7LM04lZRqnAML3Lw-NNJHicNlgeVcx4ad1x_WDQlTDYWyfxMeyJHwjD7BmLJuUOUJu5msdDOeP8CABB-hn6m9zPJvvsj55rsEvgOlZvKi0grv-sQM106jGK4Pr7gT3gcwmf58CIhWbAQqT1KdJY=w1282-h722-no
Mmmmm bigno io le tue foto non le vedo !
bigno72":7ainy8a3 ha detto:
boxer17":7ainy8a3 ha detto:
Chiaro che se non c'è la fognatura serve per "digerire" e limitare i reflui da inviare al pozzo disperdente.
Spetta, la fossa biologica o fossa settica e il pozzo perdente per me sono la stessa cosa! :scratch)
Comunque ne' qui a Ge ne' su in Piemonte e' richiesto nulla se ti allacci alla fognatura. (e l'allaccio alla fognatura dove questa e' presente e' obbligatorio)
Ma si, te l'ho detto, va da comune a comune.
Comunque:
http://deltamanufatti.com/wp-content/up ... 25-150.jpg
La fossa biologica imhoff tratta i liquami in un certo modo. Forometrie e volumi vengono dimensionati in base alla quantità di persone che la utilizzano per garantire un certo tempo di permanenza nella vasca durante il quale avvengono determinate reazioni chimiche che........alla fine restituiscono alla rete fognaria dei reflui con determinati parametri, e sono ovviamente costituiti per la maggior parte da acqua, senza parti solide etc. I vari regolamenti in zona richiedono espressamente questo tipo di vasche.
Poi le senti chiamere fosse biologiche, settiche o altro e magari sono delle "imhoff".
Però ci sono anche altri tipi di vasche che fanno sedimentare i reflui, che non sono imhoff (viste solo su carta però, dato che qui..non servono).
Qualcuno chiama fossa settica anche una semplice vasca dove si raccolgono i liquami che poi vengono regolarmente aspirati e smaltiti.
https://www.oppo.it/materiali/vasca_imhoff.html
I pozzi perdenti o meglio disperdenti invece...
http://www.zambetti.it/manufatti-per-il ... i-perdenti
Semplicemente servono per raccogliere momentaneamente un certo volume d'acqua (prendi un temporale) e disperderlo man mano nella falda freatica.
Andrebbe dimensionato anche in base al tipo di terreno, permeabile o meno.
Nel tuo caso (e in molti altri), dove ci sono case molto sparse e non c'è la fognatura, in genere è permesso disperdere i liquami tramite un pozzo disperdente.
Se prima diminuisci "la parte solida" con una fossa biologica, il pozzo dura tanto. Se butti dentro tutto e lo usi in continuazione...si satura. Non disperde più.
(Adesso hanno legiferato in merito all'invarianza idraulica per le nuove costruzioni...te lo spiego poi :asd) mi vien da piangere, soldi sotterrati)
bigno72":2pusjblq ha detto:
Le discese di alcuni sono salite per altri. :smokin)
°maCHo°":2jcssspo ha detto:
dov'è il mio amico mad ? :swear) :swear) :swear) :swear) :swear)
è fugace ultmamente
Alura, la frutta non s'importa mica da sola. :swear) :swear)
Qualche pratica da sbrigare sul campo. :smokin)
MAD147":1i921c1m ha detto:
Belin e' arrivato il filosofo mia!
Mia, distorto in mea dai diversamente genovesi che si ostinanto a parlare genovese, significa guarda.
Ovviamente non e' volgare ma e' un intercalare usato solo dalla frange piu' grezze della popolazione (i portuali, vorrebbe un antico pregiudizio).
bigno72":2x992tvx ha detto:
MAD147":2x992tvx ha detto:
Il camallo non è grezzo ma privo di inutili sovrastrutture :smokin)
bigno72":2utlr3v9 ha detto:
Ah, la superficie piezometrica inclinata! :asd) :clap) :swear)
Belìn, proprio tu, "idraulico" come sei, te ne stupisci...
Non tutte le falde sono chiuse sotto, non è detto che l'acqua sia proprio ferma...
boxer17":28o8znkx ha detto:
bigno72":28o8znkx ha detto:
Certo ma vai a intuire l'influenza del movimento cosi' lento su quelle proporzioni, se non sei avvezzo a ragionar di geologia. ;)
Prove di collocamento.
Il poggiabraccio e' troppo imponente.
La precisione del piatto non e' ancora soddisfacente.
C1KdjEClxprCmeD7gG3rXrVwiz9Yri-tUdj5Rm5wlp_OR_9k6vWtSveHNDkF1b3VzKmfqLuWvEP-QSYJadWQxbmTm5uXNuosPk0xo6ETq9sE-TurhcgW8MKT8O1bU3TlnyGWnM0IXdulgt4I7T-C4e6zlZxth-GPcXN41HaPpFTSINf_arBgphmoWSR1L_rvFbTReAI0fJPzkVOVIEc0iR-z7NLbAinyP7EaXQsUlGVb7V4dxorNl4BOXGW62QVUB13cl_8AcGrA5O-SWMNUu7hsW4yv2qrspET-JF7NGbBzzFCWRbpWuHIMammultEcbhGzkiiwEW43pLjIvHFWduMdYvak51tWJ7NuureA7vyOZ7HGQ75Hy7ZS577xJi820ltTH8iaPBCsLwqx-5gbkbVoqAyOlITwZNbLjlR2eTq5YAgXRb_PNp82d4u6-iiToK4CT3dzof3gzS_OQ6SIiO7sytLM6PHC0okNzFR9HPAgLiK3ONxDu6CJyOECnmmDXma44_Oh8vsRY13c1vqwCVvqAiK8UqiKSCDmh-8gE8cGhd9XRz7tvUBnFfpfOdjl1dulG6Oq1BNaGBo4PLCST7vAZ55UFG-MLIJQAphZXJIXKxBL2_93VpDPGSMJYARnr2-ok1zbOe9AgMELwz2aWxjdDQDatPG79oikkWnsCVlsh5VwEhQRjyzexEaGojWnq8wATxGV8ExlBpqpIEyV5pDN=w693-h923-no
Niente foto ma sto usando un cloud di image
Inviato dal mio Mi MIX 2S utilizzando Tapatalk
Stato
