I can try to answer for a couple of questions
Yes, i think u can order it..Bruno will have to send all over Italy, i think..so..one will go to Holland..more to pay for sending, but not a big problem (anyway i don't know exactly how Bruno will send everyone the interface ).
:shrug03)
How it works..well..Bruno created a couple of video in for the connect :elio)
If i remebere well, there is one composite video, and one RGB, and another one for an optional rear view camera.
U just have to connect the interface to a connector in the nav+ (don't know exactly where, but Bruno says it is more than simple :OK) ), and the video is ok.
The bigger problem is the audio, for the audio it uses the cd changer channel.
With a cable u will connect your new dvd player, or whaterver u want :nod) , to the interface, as u will do for the cd changer.
Normally, the audio from cd changer will just pass trought, and go to the nav; then, if u select the video in, u will have the audio of the source (obiouvsly u have to select the cd changer on the nav, cause audio, as i said, uses that channel).
It comes this way cause there is not an audio in, and cause the only way to select the cd changer channel is to abilitate it from nav (u cannot use that channel if u haven't got a cdc..so..who hasn't got it, will use an fm modulator :ka) ).
Let's talk about the rear view camera: simply, when u will put the backway gear (is it a good name ?? :confusbig) ..i hope u got it anyway :asd) ) the video of the camera will be on the nav, automaticaly (and it will be specular, so that u see it in the right way..otrherways u would see what is on the right, on the left of screen, and same for other side).
I hope u got everythink..that's not so easy to explain in english..also cause my english is not well "trained".. :asd)
Bye :ciao)
:shrug03)
Bye :ciao)
