Allora come driver per fare la prova ti consiglio laserjet 4/4m PS (era una vecchia stampante che usavo io!).
Viene fuori qualcosa del genere
%-12345X@PJL JOB
@PJL SET RESOLUTION=600
@PJL ENTER LANGUAGE = POSTSCRIPT
%!PS-Adobe-3.0
%%Title: Microsoft Word - Documento1
%%Creator: PScript5.dll Version 5.2.2
%%CreationDate: 5/2/2005 19:29:16
%%For: Administrator
%%BoundingBox: (atend)
%%Pages: (atend)
%%Orientation: Portrait
%%PageOrder: Special
%%DocumentNeededResources: (atend)
%%DocumentSuppliedResources: (atend)
%%DocumentData: Clean7Bit
%%TargetDevice: (LaserJet 4) (2011.110) 1
%%LanguageLevel: 2
%%EndComments
%%BeginDefaults
%%PageBoundingBox: 14 13 581 829
%%ViewingOrientation: 1 0 0 1
%%EndDefaults
%%BeginProlog
%%BeginResource: file Pscript_WinNT_ErrorHandler 5.0 0
/currentpacking where{pop/oldpack currentpacking def/setpacking where{pop false
setpacking}if}if/$brkpage 64 dict def $brkpage begin/prnt{dup type/stringtype
ne{=string cvs}if dup length 6 mul/tx exch def/ty 10 def currentpoint/toy exch
def/tox exch def 1 setgray newpath tox toy 2 sub moveto 0 ty rlineto tx 0
rlineto 0 ty neg rlineto closepath fill tox toy moveto 0 setgray show}bind def
/nl{currentpoint exch pop lmargin exch moveto 0 -10 rmoveto}def/=={/cp 0 def
typeprint nl}def/typeprint{dup type exec}readonly def/lmargin 72 def/rmargin 72
def/tprint{dup length cp add rmargin gt{nl/cp 0 def}if dup length cp add/cp
exch def prnt}readonly def/cvsprint{=string cvs tprint( )tprint}readonly def
/integertype{cvsprint}readonly def/realtype{cvsprint}readonly def/booleantype
{cvsprint}readonly def/operatortype{(--)tprint =string cvs tprint(-- )tprint}
readonly def/marktype{pop(-mark- )tprint}readonly def/dicttype{pop
(-dictionary- )tprint}readonly def/nulltype{pop(-null- )tprint}readonly def
/filetype{pop(-filestream- )tprint}readonly def/savetype{pop(-savelevel- )
tprint}readonly def/fonttype{pop(-fontid- )tprint}readonly def/nametype{dup
xcheck not{(/)tprint}if cvsprint}readonly def/stringtype{dup rcheck{(\()tprint
tprint(\))tprint}{pop(-string- )tprint}ifelse}readonly def/arraytype{dup rcheck
{dup xcheck{({)tprint{typeprint}forall(})tprint}{([)tprint{typeprint}forall(])
tprint}ifelse}{pop(-array- )tprint}ifelse}readonly def/packedarraytype{dup
rcheck{dup xcheck{({)tprint{typeprint}forall(})tprint}{([)tprint{typeprint}
forall(])tprint}ifelse}{pop(-packedarray- )tprint}ifelse}readonly def/courier
/Courier findfont 10 scalefont def end errordict/handleerror{systemdict begin
$error begin $brkpage begin newerror{/newerror false store vmstatus pop pop 0
ne{grestoreall}if errorname(VMerror)ne{showpage}if initgraphics courier setfont
lmargin 720 moveto errorname(VMerror)eq{userdict/ehsave known{clear userdict
/ehsave get restore 2 vmreclaim}if vmstatus exch pop exch pop PrtVMMsg}{
(ERROR: )prnt errorname prnt nl(OFFENDING COMMAND: )prnt/command load prnt
$error/ostack known{nl nl(STACK
prnt nl nl $error/ostack get aload length{==}
repeat}if}ifelse systemdict/showpage get exec(%%[ Error: )print errorname
=print(; OffendingCommand: )print/command load =print( ]%%)= flush}if end end
end}dup 0 systemdict put dup 4 $brkpage put bind readonly put/currentpacking
where{pop/setpacking where{pop oldpack setpacking}if}if
%%EndResource
userdict /Pscript_WinNT_Incr 230 dict dup begin put
%%BeginResource: file Pscript_FatalError 5.0 0
userdict begin/FatalErrorIf{{initgraphics findfont 1 index 0 eq{exch pop}{dup
length dict begin{1 index/FID ne{def}{pop pop}ifelse}forall/Encoding
{ISOLatin1Encoding}stopped{StandardEncoding}if def currentdict end
/ErrFont-Latin1 exch definefont}ifelse exch scalefont setfont counttomark 3 div
cvi{moveto show}repeat showpage quit}{cleartomark}ifelse}bind def end
%%EndResource
userdict begin/PrtVMMsg{vmstatus exch sub exch pop gt{[
(Questo lavoro richiede una quantità di memoria maggiore di quella disponibile nella stampante.)
100 500(Attenersi alle istruzioni seguenti; quindi stampare di nuovo
100 485
(Per il formato di output, scegliere Massima portabilità.)115 470
(Controllare che la quantità di memoria PostScript disponibile sia accurata nella scheda Impostazioni periferica.)
115 455(Ridurre il numero di caratteri del documento.)115 440
(Stampare il documento in parti.)115 425 12/Times-Roman showpage
(%%[ PrinterError: Low Printer VM ]%%)= true FatalErrorIf}if}bind def end
version cvi 2016 ge{/VM?{pop}bind def}{/VM? userdict/PrtVMMsg get def}ifelse
105000 VM?
%%BeginResource: file Pscript_Win_Basic 5.0 0
/d/def load def/,/load load d/~/exch , d/?/ifelse , d/!/pop , d/`/begin , d/^
/index , d/@/dup , d/+/translate , d/$/roll , d/U/userdict , d/M/moveto , d/-
/rlineto , d/&/currentdict , d/:/gsave , d/;/grestore , d/F/false , d/T/true ,
d/N/newpath , d/E/end , d/Ac/arc , d/An/arcn , d/A/ashow , d/D/awidthshow , d/C
/closepath , d/V/div , d/O/eofill , d/L/fill , d/I/lineto , d/-c/curveto , d/-M
/rmoveto , d/+S/scale , d/Ji/setfont , d/Lc/setlinecap , d/Lj/setlinejoin , d
/Lw/setlinewidth , d/Lm/setmiterlimit , d/sd/setdash , d/S/show , d/LH/showpage
, d/K/stroke , d/W/widthshow , d/R/rotate , d/L2? false/languagelevel where{pop
languagelevel 2 ge{pop true}if}if d L2?{/xS/xshow , d/yS/yshow , d/zS/xyshow ,
d}if/b{bind d}bind d/bd{bind d}bind d/xd{~ d}bd/ld{, d}bd/bn/bind ld/lw/Lw ld
/lc/Lc ld/lj/Lj ld/sg/setgray ld/ADO_mxRot null d/self & d/OrgMx matrix
currentmatrix d/reinitialize{: OrgMx setmatrix[/TextInit/GraphInit/UtilsInit
counttomark{@ where{self eq}{F}?{cvx exec}{!}?}repeat cleartomark ;}b
/initialize{`{/Pscript_Win_Data where{!}{U/Pscript_Win_Data & put}?/ADO_mxRot ~
d/TextInitialised? F d reinitialize E}{U/Pscript_Win_Data 230 dict @ ` put
/ADO_mxRot ~ d/TextInitialised? F d reinitialize}?}b/terminate{!{& self eq
{exit}{E}?}loop E}b/suspend/terminate , d/resume{` Pscript_Win_Data `}b U `
/lucas 21690 d/featurebegin{countdictstack lucas[}b/featurecleanup{stopped
{cleartomark @ lucas eq{! exit}if}loop countdictstack ~ sub @ 0 gt{{E}repeat}
{!}?}b E/snap{transform 0.25 sub round 0.25 add ~ 0.25 sub round 0.25 add ~
itransform}b/dsnap{dtransform round ~ round ~ idtransform}b/nonzero_round{@ 0.5
ge{round}{@ -0.5 lt{round}{0 ge{1}{-1}?}?}?}b/nonzero_dsnap{dtransform
nonzero_round ~ nonzero_round ~ idtransform}b U<04>cvn{}put/rr{1 ^ 0 - 0 ~ -
neg 0 - C}b/irp{4 -2 $ + +S fx 4 2 $ M 1 ^ 0 - 0 ~ - neg 0 -}b/rp{4 2 $ M 1 ^ 0
- 0 ~ - neg 0 -}b/solid{[]0 sd}b/g{@ not{U/DefIf_save save put}if U/DefIf_bool
2 ^ put}b/DefIf_El{if U/DefIf_bool get not @{U/DefIf_save get restore}if}b/e
{DefIf_El !}b/UDF{L2?{undefinefont}{!}?}b/UDR{L2?{undefineresource}{! !}?}b
/freeVM{/Courier findfont[40 0 0 -40 0 0]makefont Ji 2 vmreclaim}b/hfRedefFont
{findfont @ length dict `{1 ^/FID ne{d}{! !}?}forall & E @ ` ~{/CharStrings 1
dict `/.notdef 0 d & E d}if/Encoding 256 array 0 1 255{1 ^ ~/.notdef put}for d
E definefont !}bind d/hfMkCIDFont{/CIDFont findresource @ length 2 add dict `{1
^ @/FID eq ~ @/XUID eq ~/UIDBase eq or or{! !}{d}?}forall/CDevProc ~ d/Metrics2
16 dict d/CIDFontName 1 ^ d & E 1 ^ ~/CIDFont defineresource ![~]composefont !}
bind d
%%EndResource
%%BeginResource: file Pscript_Win_Utils_L2 5.0 0
/rf/rectfill , d/fx{1 1 dtransform @ 0 ge{1 sub 0.5}{1 add -0.5}? 3 -1 $ @ 0 ge
{1 sub 0.5}{1 add -0.5}? 3 1 $ 4 1 $ idtransform 4 -2 $ idtransform}b/BZ{4 -2 $
snap + +S fx rf}b/rs/rectstroke , d/rc/rectclip , d/UtilsInit{currentglobal{F
setglobal}if}b/scol{! setcolor}b/colspA/DeviceGray d/colspABC/DeviceRGB d
/colspRefresh{colspABC setcolorspace}b/SetColSpace{colspABC setcolorspace}b
/resourcestatus where{!/ColorRendering/ProcSet resourcestatus{! ! T}{F}?}{F}?
not{/ColorRendering<</GetHalftoneName{currenthalftone @/HalftoneName known{
/HalftoneName get}{!/none}?}bn/GetPageDeviceName{currentpagedevice @
/PageDeviceName known{/PageDeviceName get @ null eq{!/none}if}{!/none}?}bn
/GetSubstituteCRD{!/DefaultColorRendering/ColorRendering resourcestatus{! !
/DefaultColorRendering}{(DefaultColorRendering*){cvn exit}127 string
/ColorRendering resourceforall}?}bn>>/defineresource where{!/ProcSet
defineresource !}{! !}?}if/buildcrdname{/ColorRendering/ProcSet findresource `
mark GetHalftoneName @ type @/nametype ne ~/stringtype ne and{!/none}if(.)
GetPageDeviceName @ type @/nametype ne ~/stringtype ne and{!/none}if(.)5 ^ 0 5
-1 1{^ length add}for string 6 1 $ 5 ^ 5{~ 1 ^ cvs length 1 ^ length 1 ^ sub
getinterval}repeat ! cvn 3 1 $ ! ! E}b/definecolorrendering{~ buildcrdname ~
/ColorRendering defineresource !}b/findcolorrendering where{!}{
/findcolorrendering{buildcrdname @/ColorRendering resourcestatus{! ! T}{
/ColorRendering/ProcSet findresource ` GetSubstituteCRD E F}?}b}?
/selectcolorrendering{findcolorrendering !/ColorRendering findresource
setcolorrendering}b/G2UBegin{findresource/FontInfo get/GlyphNames2Unicode get
`}bind d/G2CCBegin{findresource/FontInfo get/GlyphNames2HostCode get `}bind d
/G2UEnd{E}bind d/AddFontInfoBegin{/FontInfo 8 dict @ `}bind d/AddFontInfo{
/GlyphNames2Unicode 16 dict d/GlyphNames2HostCode 16 dict d}bind d
/AddFontInfoEnd{E d}bind d/T0AddCFFMtx2{/CIDFont findresource/Metrics2 get ` d
E}bind d
%%EndResource
end
%%EndProlog
%%BeginSetup
statusdict begin (%%[ ProductName: ) print product print ( ]%%)= flush end
[ 1 0 0 1 0 0 ] false Pscript_WinNT_Incr dup /initialize get exec
featurebegin{
%%BeginNonPPDFeature: JobTimeout 0
0 /languagelevel where{pop languagelevel}{1}ifelse 2 ge{1 dict dup/JobTimeout 4 -1 roll put setuserparams}{statusdict/setjobtimeout get exec}ifelse
%%EndNonPPDFeature
}featurecleanup
featurebegin{
%%BeginNonPPDFeature: WaitTimeout 300
300 /languagelevel where{pop languagelevel}{1}ifelse 2 ge{1 dict dup/WaitTimeout 4 -1 roll put setuserparams}{statusdict/waittimeout 3 -1 roll put}ifelse
%%EndNonPPDFeature
}featurecleanup
featurebegin{
%%BeginFeature: *PageSize A4
1 dict
dup /Policies 2 dict dup /PageSize 2 put dup /MediaType 0 put put
setpagedevice
2 dict
dup /PageSize [595 842] put
dup /ImagingBBox null put
setpagedevice
%%EndFeature
}featurecleanup
featurebegin{
%%BeginFeature: *Option1 False
%%EndFeature
}featurecleanup
featurebegin{
%%BeginFeature: *Option2 False
%%EndFeature
}featurecleanup
featurebegin{
%%BeginFeature: *Resolution 600dpi
%%EndFeature
}featurecleanup
1 setlinecap 1 setlinejoin
/mysetup [ 72 600 V 0 0 -72 600 V 14.00031 829.00067 ] def
%%EndSetup
userdict begin /ehsave save def end
%%Page: 1 1
%%EndPageComments
%%BeginPageSetup
/DeviceRGB dup setcolorspace /colspABC exch def
mysetup concat colspRefresh
%%EndPageSetup
/DeviceGray dup setcolorspace /colspABC exch def
0 0 scol Pscript_WinNT_Incr begin
%%BeginResource: file Pscript_Text 5.0 0
/TextInit{TextInitialised? not{/Pscript_Windows_Font & d/TextInitialised? T d
/fM[1 0 0 1 0 0]d/mFM matrix d/iMat[1 0 0.212557 1 0 0]d}if}b/copyfont{1 ^
length add dict `{1 ^/FID ne{d}{! !}?}forall & E}b/EncodeDict 11 dict d/bullets
{{/bullet}repeat}b/rF{3 copyfont @ ` ~ EncodeDict ~ get/Encoding ~ 3 ^/0 eq{&
/CharStrings known{CharStrings/Eth known not{! EncodeDict/ANSIEncodingOld get}
if}if}if d E}b/mF{@ 7 1 $ findfont ~{@/Encoding get @ StandardEncoding eq{! T}{
{ISOLatin1Encoding}stopped{! F}{eq}?{T}{@ ` T 32 1 127{Encoding 1 ^ get
StandardEncoding 3 -1 $ get eq and}for E}?}?}{F}?{1 ^ ~ rF}{0 copyfont}? 6 -2 $
! ! ~ !/pd_charset @ where{~ get 128 eq{@ FDV 2 copy get @ length array copy
put pd_CoverFCRange}if}{!}? 2 ^ ~ definefont fM 5 4 -1 $ put fM 4 0 put fM
makefont Pscript_Windows_Font 3 1 $ put}b/sLT{: Lw -M currentpoint snap M 0 - 0
Lc K ;}b/xUP null d/yUP null d/uW null d/xSP null d/ySP null d/sW null d/sSU{N
/uW ~ d/yUP ~ d/xUP ~ d}b/sU{xUP yUP uW sLT}b/sST{N/sW ~ d/ySP ~ d/xSP ~ d}b/sT
{xSP ySP sW sLT}b/sR{: + R 0 0 M}b/sRxy{: matrix astore concat 0 0 M}b/eR/; , d
/AddOrigFP{{&/FontInfo known{&/FontInfo get length 6 add}{6}? dict `
/WinPitchAndFamily ~ d/WinCharSet ~ d/OrigFontType ~ d/OrigFontStyle ~ d
/OrigFontName ~ d & E/FontInfo ~ d}{! ! ! ! !}?}b/mFS{makefont
Pscript_Windows_Font 3 1 $ put}b/mF42D{0 copyfont `/FontName ~ d 2 copy ~ sub 1
add dict `/.notdef 0 d 2 copy 1 ~{@ 3 ^ sub Encoding ~ get ~ d}for & E
/CharStrings ~ d ! ! & @ E/FontName get ~ definefont}b/mF42{15 dict ` @ 4 1 $
FontName ~ d/FontType 0 d/FMapType 2 d/FontMatrix[1 0 0 1 0 0]d 1 ^ 254 add 255
idiv @ array/Encoding ~ d 0 1 3 -1 $ 1 sub{@ Encoding 3 1 $ put}for/FDepVector
Encoding length array d/CharStrings 2 dict `/.notdef 0 d & E d 0 1 Encoding
length 1 sub{@ @ 10 lt{! FontName length 1 add string}{100 lt{FontName length 2
add string}{FontName length 3 add string}?}? @ 0 FontName @ length string cvs
putinterval @ 3 -1 $ @ 4 1 $ 3 string cvs FontName length ~ putinterval cvn 1 ^
256 mul @ 255 add 3 -1 $ 4 ^ findfont mF42D FDepVector 3 1 $ put}for & @ E
/FontName get ~ definefont ! ! ! mF}b/mF_OTF_V{~ ! ~ ! 4 -1 $ ! findfont 2 ^ ~
definefont fM @ @ 4 6 -1 $ neg put 5 0 put 90 matrix R matrix concatmatrix
makefont Pscript_Windows_Font 3 1 $ put}b/mF_TTF_V{3{~ !}repeat 3 -1 $ !
findfont 1 ^ ~ definefont Pscript_Windows_Font 3 1 $ put}b/UmF{L2?
{Pscript_Windows_Font ~ undef}{!}?}b/UmF42{@ findfont/FDepVector get{/FontName
get undefinefont}forall undefinefont}b
%%EndResource
end reinitialize
%%BeginResource: file Pscript_Encoding256 5.0 0
/CharCol256Encoding[/.notdef/breve/caron/dotaccent/dotlessi/fi/fl/fraction
/hungarumlaut/Lslash/lslash/minus/ogonek/ring/Zcaron/zcaron/.notdef/.notdef
/.notdef/.notdef/.notdef/.notdef/.notdef/.notdef/.notdef/.notdef/.notdef
/.notdef/.notdef/.notdef/.notdef/.notdef/space/exclam/quotedbl/numbersign
/dollar/percent/ampersand/quotesingle/parenleft/parenright/asterisk/plus/comma
/hyphen/period/slash/zero/one/two/three/four/five/six/seven/eight/nine/colon
/semicolon/less/equal/greater/question/at/A/B/C/D/E/F/G/H/I/J/K/L/M/N/O/P/Q/R/S
/T/U/V/W/X/Y/Z/bracketleft/backslash/bracketright/asciicircum/underscore/grave
/a/b/c/d/e/f/g/h/i/j/k/l/m/n/o/p/q/r/s/t/u/v/w/x/y/z/braceleft/bar/braceright
/asciitilde/.notdef/Euro/.notdef/quotesinglbase/florin/quotedblbase/ellipsis
/dagger/daggerdbl/circumflex/perthousand/Scaron/guilsinglleft/OE/.notdef
/.notdef/.notdef/.notdef/quoteleft/quoteright/quotedblleft/quotedblright/bullet
/endash/emdash/tilde/trademark/scaron/guilsinglright/oe/.notdef/.notdef
/Ydieresis/.notdef/exclamdown/cent/sterling/currency/yen/brokenbar/section
/dieresis/copyright/ordfeminine/guillemotleft/logicalnot/.notdef/registered
/macron/degree/plusminus/twosuperior/threesuperior/acute/mu/paragraph
/periodcentered/cedilla/onesuperior/ordmasculine/guillemotright/onequarter
/onehalf/threequarters/questiondown/Agrave/Aacute/Acircumflex/Atilde/Adieresis
/Aring/AE/Ccedilla/Egrave/Eacute/Ecircumflex/Edieresis/Igrave/Iacute
/Icircumflex/Idieresis/Eth/Ntilde/Ograve/Oacute/Ocircumflex/Otilde/Odieresis
/multiply/Oslash/Ugrave/Uacute/Ucircumflex/Udieresis/Yacute/Thorn/germandbls
/agrave/aacute/acircumflex/atilde/adieresis/aring/ae/ccedilla/egrave/eacute
/ecircumflex/edieresis/igrave/iacute/icircumflex/idieresis/eth/ntilde/ograve
/oacute/ocircumflex/otilde/odieresis/divide/oslash/ugrave/uacute/ucircumflex
/udieresis/yacute/thorn/ydieresis]def EncodeDict/256 CharCol256Encoding put
%%EndResource
end reinitialize
%%IncludeResource: font Times-Roman
%%BeginResource: file Pscript_Win_Euro_L2 5.0 0
/UseT3EuroFont{/currentdistillerparams where{pop currentdistillerparams
/CoreDistVersion get 4000 le}{false}ifelse}bind def/NewEuroT3Font?{dup/FontType
get 3 eq{dup/EuroFont known exch/BaseFont known and}{pop false}ifelse}bind def
/T1FontHasEuro{dup/CharStrings known not{dup NewEuroT3Font?{dup/EuroGlyphName
get exch/EuroFont get/CharStrings get exch known{true}{false}ifelse}{pop false}
ifelse}{dup/FontType get 1 eq{/CharStrings get/Euro known}{dup/InfoDict known{
/InfoDict get/Euro known}{/CharStrings get/Euro known}ifelse}ifelse}ifelse}bind
def/FontHasEuro{findfont dup/Blend known{pop true}{T1FontHasEuro}ifelse}bind
def/EuroEncodingIdx 1 def/EuroFontHdr{12 dict begin/FontInfo 10 dict dup begin
/version(001.000)readonly def/Notice(Copyright (c)1999 Adobe Systems
Incorporated. All Rights Reserved.)readonly def/FullName(Euro)readonly def
/FamilyName(Euro)readonly def/Weight(Regular)readonly def/isFixedPitch false
def/ItalicAngle 0 def/UnderlinePosition -100 def/UnderlineThickness 50 def end
readonly def/FontName/Euro def/Encoding 256 array 0 1 255{1 index exch/.notdef
put}for def/PaintType 0 def/FontType 1 def/FontMatrix[0.001 0 0 0.001 0 0]def
/FontBBox{-25 -23 1500 804}readonly def currentdict end dup/Private 20 dict dup
begin/ND{def}def/NP{put}def/lenIV -1 def/RD{string currentfile exch
readhexstring pop}def/-|{string currentfile exch readstring pop}executeonly def
/|-{def}executeonly def/|{put}executeonly def/BlueValues[-20 0 706 736 547 572]
|-/OtherBlues[-211 -203]|-/BlueScale 0.0312917 def/MinFeature{16 16}|-/StdHW
[60]|-/StdVW[71]|-/ForceBold false def/password 5839 def/Erode{8.5 dup 3 -1
roll 0.1 mul exch 0.5 sub mul cvi sub dup mul 71 0 dtransform dup mul exch dup
mul add le{pop pop 1.0 1.0}{pop pop 0.0 1.5}ifelse}def/OtherSubrs[{}{}{}
{systemdict/internaldict known not{pop 3}{1183615869 systemdict/internaldict
get exec dup/startlock known{/startlock get exec}{dup/strtlck known{/strtlck
get exec}{pop 3}ifelse}ifelse}ifelse}executeonly]|-/Subrs 5 array dup 0
<8E8B0C100C110C110C210B>put dup 1<8B8C0C100B>put dup 2<8B8D0C100B>put dup 3<0B>
put dup 4<8E8C8E0C100C110A0B>put |- 2 index/CharStrings 256 dict dup begin
/.notdef<8b8b0d0e>def end end put put dup/FontName get exch definefont pop}bind
def/AddEuroGlyph{2 index exch EuroEncodingIdx 1 eq{EuroFontHdr}if systemdict
begin/Euro findfont dup dup/Encoding get 5 1 roll/Private get begin/CharStrings
get dup 3 index known{pop pop pop pop end end}{begin 1 index exch def end end
end EuroEncodingIdx dup 1 add/EuroEncodingIdx exch def exch put}ifelse}bind def
/GetNewXUID{currentdict/XUID known{[7 XUID aload pop]true}{currentdict/UniqueID
known{[7 UniqueID]true}{false}ifelse}ifelse}bind def/BuildT3EuroFont{exch 16
dict begin dup/FontName exch def findfont dup/Encoding get/Encoding exch def
dup length 1 add dict copy dup/FID undef begin dup dup/FontName exch def
/Encoding 256 array 0 1 255{1 index exch/.notdef put}for def GetNewXUID{/XUID
exch def}if currentdict end definefont pop/BaseFont exch findfont 1000
scalefont def/EuroFont exch findfont 1000 scalefont def pop/EuroGlyphName exch
def/FontType 3 def/FontMatrix[.001 0 0 .001 0 0]def/FontBBox BaseFont/FontBBox
get def/Char 1 string def/BuildChar{exch dup begin/Encoding get 1 index get
/Euro eq{BaseFont T1FontHasEuro{false}{true}ifelse}{false}ifelse{EuroFont
setfont pop userdict/Idx 0 put EuroFont/Encoding get{EuroGlyphName eq{exit}
{userdict/Idx Idx 1 add put}ifelse}forall userdict/Idx get}{dup dup Encoding
exch get BaseFont/Encoding get 3 1 roll put BaseFont setfont}ifelse Char 0 3 -1
roll put Char stringwidth newpath 0 0 moveto Char true charpath flattenpath
pathbbox setcachedevice 0 0 moveto Char show end}bind def currentdict end dup
/FontName get exch definefont pop}bind def/AddEuroToT1Font{dup findfont dup
length 10 add dict copy dup/FID undef begin/EuroFont 3 -1 roll findfont 1000
scalefont def CharStrings dup length 1 add dict copy begin/Euro{EuroFont
setfont pop EuroGBBox aload pop setcachedevice 0 0 moveto EuroGName glyphshow}
bind def currentdict end/CharStrings exch def GetNewXUID{/XUID exch def}if 3 1
roll/EuroGBBox exch def/EuroGName exch def currentdict end definefont pop}bind
def/BuildNewFont{UseT3EuroFont{BuildT3EuroFont}{pop AddEuroToT1Font}ifelse}bind
def/UseObliqueEuro{findfont/FontMatrix get dup 2 get 0 eq exch dup 0 get exch 3
get eq and UseT3EuroFont or}bind def
%%EndResource
end reinitialize
7500 VM?
/Times-Roman FontHasEuro not
/Euro.Times-Roman
[500 0 24 -14 493 676 ]
<A3F8880DC0EB03F854F743950C0C037DA501F7A0BB01F805BB01F91EA501F869F8911584
F73A0576068478827E7F8B087F8B70AC438B082A8BFB0D6471FB700863067C5B05BE068A
7E8B878B7D08750764067D5B05C206A0FB7BF71858E88B088F0AC0EB03F84BF789950C0C
037DA501F7A0BB01F805BB01F91EA501CA8BACAC998B08988B95809076088F0AC0EB03F8
54F743950C0C037DA501F7A0BB01F805BB01F91EA501A00692F73705750675FB09417667
8B083A8B43C182F75E08F7740699BB05FB84069C078B978C978B9708F7950699BB05FBA1
069AF755D5B3D18B08AB8BDD71A2FB0708090E>
AddEuroGlyph
/Euro /Times-Roman /Times-Roman-Copy BuildNewFont
} if
F /F0 0 /256 T /Times-Roman mF
/F0S64 F0 [100 0 0 -100 0 0 ] mFS
F0S64 Ji
355 572 M (Prova di stampa)[56 33 50 50 44 25 50 28 25 39 28 44 78 50 0]xS
999 572 M ( )S
355 687 M ( )S
LH
(%%[Page: 1]%%) =
%%PageTrailer
%%Trailer
%%BoundingBox: 14 13 581 829
%%+ font Times-Roman
%%+ procset Pscript_WinNT_ErrorHandler 5.0 0
%%+ procset Pscript_FatalError 5.0 0
%%+ procset Pscript_Win_Basic 5.0 0
%%+ procset Pscript_Win_Utils_L2 5.0 0
%%+ procset Pscript_Text 5.0 0
%%+ procset Pscript_Encoding256 5.0 0
%%+ procset Pscript_Win_Euro_L2 5.0 0
Pscript_WinNT_Incr dup /terminate get exec
ehsave restore
%%Pages: 1
(%%[LastPage]%%) =
%%EOF
%-12345X@PJL EOJ
%-12345X
