Io ho seguito passo passo ciò che mi hai indicato nel file unbu1 ma non funziona..
ho fatto come hai fatto tu:
aperto il terminale, compilato, riavviato a avviato in root mode ecc. ecc.
Ti incollo di seguito il report del log file di questa fatidica installazione..
nvidia-installer log file '/var/log/nvidia-installer.log'
creation time: Wed Nov 21 00:28:33 2007
option status:
license pre-accepted : false
update : false
force update : false
expert : false
uninstall : false
driver info : false
precompiled interfaces : true
no ncurses color : false
query latest version : false
OpenGL header files : true
no questions : false
silent : false
no recursion : false
no backup : false
kernel module only : false
sanity : false
add this kernel : false
no runlevel check : false
no network : false
no ABI note : false
no RPMs : false
no kernel module : false
force SELinux : default
no X server check : false
force tls : (not specified)
X install prefix : (not specified)
X library install path : (not specified)
X module install path : (not specified)
OpenGL install prefix : (not specified)
OpenGL install libdir : (not specified)
utility install prefix : (not specified)
utility install libdir : (not specified)
doc install prefix : (not specified)
kernel name : (not specified)
kernel include path : (not specified)
kernel source path : (not specified)
kernel output path : (not specified)
kernel install path : (not specified)
proc mount point : /proc
ui : (not specified)
tmpdir : /tmp
ftp mirror :
ftp://download.nvidia.com
RPM file list : (not specified)
Using: nvidia-installer ncurses user interface
-> You appear to be running in runlevel 1; this may cause problems. For exampl
e: some distributions that use devfs do not run the devfs daemon in runlevel
1, making it difficult for `nvidia-installer` to correctly setup the kernel
module configuration files. It is recommended that you quit installation now and switch to runlevel 3 (`telinit 3`) before installing.
Quit installation now? (select 'No' to continue installation) (Answer: No)
-> License accepted.
-> No precompiled kernel interface was found to match your kernel; would you like the installer to attempt to download a kernel interface for your kernel from the NVIDIA ftp site (
ftp://download.nvidia.com)? (Answer: Yes)
-> No matching precompiled kernel interface was found on the NVIDIA ftp site;
this means that the installer will need to compile a kernel interface for
your kernel.
ERROR: You do not appear to have libc header files installed on your system.
Please install your distribution's libc development package.
ERROR: Installation has failed. Please see the file
'/var/log/nvidia-installer.log' for details. You may find suggestions
on fixing installation problems in the README available on the Linux
driver download page at
www.nvidia.com.
