General specifications:
Record last updated Before 12 / 01 / 2004
Country of origin Italy
Numbers built N/A (Prototype)
Produced in 1996
Introduced at 1996 Paris Motorshow
Body design Alfa Romeo Centro Stile
Engine:
Engine 60º V 6
Engine Location Front , transversely mounted
Configuration light alloy block and head
Displacement 2.492 liter / 152.1 cu in
Bore / Stroke 88.0 mm (3.5 in) / 68.3 mm (2.7 in)
Compression ratio 8.3:1
Valvetrain 4 valves / cylinder, DOHC
Fuel feed Fuel injection
Aspiration Twin Turbo
Drivetrain:
Chassis/body glassfibre body on aluminum tubular frame
Front suspension double wishbones, transverse arms, coil springs, telescopic shock absorbers, anti-roll bar
Rear suspension double wishbones, transverse arms, coil springs, telescopic shock absorbers, anti-roll bar
Steering rack-and-pinion, power assisted
Brakes vented discs, all-round, ABS
Gearbox 6 speed Manual
Drive All wheel drive
Dimensions:
Length / Width / Height 4286 mm (168.7 in) / 1859 mm (73.2 in) / N/A
Wheelbase / Track (fr/r) 2600 mm (102.4 in) / 1577 mm (62.1 in) / 1602 mm (63.1 in)
Performance figures:
Power 300 bhp / 224 KW @ 6000 rpm
Torque 387 Nm / 285 ft lbs @ 3000 rpm
BHP/Liter 120 bhp / liter
Top Speed 280 km/h / 174 mph
0-60 mph Acceleration 6.0 s
