Virtual Laser Keyboard : Qualcuno ce l'ha??
Mah, mi sembra dura che funzioni, da quell'angolazione come fa a capire che tasti premo se ho qualche altro dito che copre la battuta?
se per. es premo spazio con il pollice ma davanti ho tutta la mano non può accorgersene...
:scratch)
vista! troppo figosa, ma ho paura che non funzioni adeguatamente. Meglio la vecchia cara tastiera a filo e amen...
O se proprio si vuole fare i diversi beh, altra classica tastiera è quela piegevole a libro "soft" specie per i notebook...
How the VKB works?
Step 1: Template creation (Projection Module)
A template of the desired interface is projected onto the adjacent interface surface. The template is produced by illuminating a specially designed, highly efficient holographic optical element with a red diode laser. Note: the template serves only as a reference for the user and is not involved in the detection process. In a fixed environment, the template can just as easily be printed onto the interface surface.
Step 2: Reference plane illumination (Micro-illumination ModuleTM)
An infra-red plane of light is generated just above, and parallel to, the interface surface. This light is invisible to the user and hovers a few millimeters above the surface. When the user touches a key position on the interface surface light is reflected from this plane in the vicinity of the key and directed towards the sensor module.
Step 3: Map reflection coordinates (Sensor Module)
Reflected light from user interactions with the interface surface is passed through an infra-red filter and imaged on to a CMOS image sensor in the sensor module. Custom hardware embedded in the sensor chip (the Virtual Interface Processing CoreTM) then makes a real-time determination of the location of the reflected light. The processing core can track multiple reflection events simultaneously and can thus support both multiple keystrokes and overlapping cursor control inputs.
Non ci credo finché non lo vedo... :asd)
Non capisco come hanno risolto il problema dell'occlusione, mi sembra tanto una sparata di marketing che poi funziona se si preme un tasto alla volta con un dito puntato in verticale... :asd)
Ne avevo già sentito parlare perchè la ditta di mio padre doveva importarle per uso ospedaliero :nod)
Adesso in sala chirurgica usano delle tastiere soft lavabili e sterilizzabili, ma quella sarebbe molto migliore in quanto per pulirla basta lavare il tavolo :asd)
Se ne ordinano vi faccio sapere :culo)
Zizzo":w7kx1d6w ha detto:
penso che un touchscreen in ambienti sterilizzati vada benone
neppure io, ma il problema delle tastiere è che pulirle bene non è facile....pensa se cola del sangue tra i tasti o germi, etc...
Tutto quello che c'è in sala deve poter essere lavato :D
