Update for Connect Nav (not Connect Nav+)
Jens33
18 Gennaio 2005
2
Hi all,
I don't speak the italian language, so I hope I'm allowed to write in english.
I'm from Germany and own an Alfa 147 with the Connect Nav (not Nav+).
Everything works fine, but 2 things are wrong:
1. the display becomes brighter automatically if I start the Alfa (cold start), after a reset of the Connect Nav (5x trip-key) the display is ok at a constant darkness.
2. sometimes the fon module doesn't start (after resetting it works - the same like 1. - cold start problem)
My question is, whether there are updates from Alfa for the Connect Nav?
My Alfa dealer says, that there is only an update for the Connect Nav+!
Thanks a lot for helping
Jens
Anche a me interesserebbe sapere se il Connect NAV usa release software differenti, qual'è l'ultima disponibile e come si conosce la propria versione...
you can find out the versions: MAIN - right button (->connect menu) - AUDIO OFF (hold AUDIO for some seconds) - key 1 - key 2 - key 3 - right button (->connect menu) -> a new menu appears, where the versions are
My Software-version:
01N937L3007.5
My Hardware-version:
05035500031.9
