Pistolando con la doc "di mio cugggino" ho rimediato tutti i motori VW, direi che c'è un ampio spettro!
5-cylinder diesel engine 2.5 L/85 kW TDIpump-jet injection system, EU 3 base engine is T03
5-cylinder diesel engine 2.5 L/115kW TDIpump-jet injection system base engine is T03/T87
8-cylinder gasoline engine 4.2 L/220 kW V8 Motronic, EU 3D base engine is T7S
8-cylinder gasoline engine 4.2 L/220 kW V8 Motronic base engine is T7S
8-cyl. gas. engine V8 4.2 L/246 kW 40V camshaft adj. w/o cylinder cutout, MPI base engine is T81
8-cyl. gas. engine 3.7 L/206 kW V8 40V camshaft adj. w/o cylinder cutout, MPI base engine is T82
4-cylinder diesel engine 2.0 L/51 kW SDIpump-jet injection system base engine is T1A
6-cyl. gasoline engine 2.7 L/280 kW 30V biturbo base engine is T0R
4-cyl. turbo diesel en. 2.0 L/118 kW 16VTDI, pump-jet injection system base engine is TB3/T9G
6-cyl. gasoline engine 2.4 L/100 kW 30V EU 4 base engine is T7T
6-cyl. diesel engine 3.0 L/155 kW TDI pump-jet injection system base engine is T07
12-cyl. gasoline engine 6.0 L/330 kW 48VWR 12, Motronic, EU 4 base engine is T08
12-cyl. gas. eng. 6.0 L/331 kW WR12 48V Motronic base engine is T1H
8-cyl. gasoline eng. 4.2 L/220 kW 40V V8base engine is T7S
8-cyl. gasoline eng. 4.2 L/331 kW 40V V8biturbo base engine is T09
4-cylinder gasoline engine 1.6 L/64 kW
4-cylinder gasoline engine 1.6 L/68 kW with catalytic converter, US 83
4-cylinder gasoline engine 1.6 L/49 kW with catalytic converter
4-cyl. gasoline engine 1.8 L/92 kW 20V EU 3D base engine is T5Z
4-cyl. gasoline engine 1.8 L/110 kW 20V turbo, EU 3D base engine is T8B
6-cyl. turbo dies. eng. 3.0 L/171 kW 24VV6 TDI, common rail base engine is T41
8-cyl. turbo dies. eng. 4.0 L/202 kW 32Vcommon rail base engine is T42
4-cyl. gasoline engine 1.8 L/110 kW 20V turbo, LEV base engine is T8B
6-cyl. turbo die. e. 2.5 L/114 kW V6 24Vfuel distributor injection pump base engine is T5T
4-cylinder gasoline engine 1.8 L/64 kW fuel injected engine, bivalent base engine is T6X
6-cyl. diesel eng. 2.5 L/110 kW TDI 24V EU 3, fuel distributor injection pump base engine is T6T
4-cylinder gasoline engine 1.6 L/65 kW BOSCH Motronic
4-cyl. gasoline engine 1.8 L/110 kW 20V turbo, EU 4 base engine is T8B
6-cyl. diesel eng. 2.5 L/125 kW 24V TDI fuel distributor injection pump base engine is T1K
6-cyl. turbo dies. eng. 2.7 L/140 kW 24VV6 TDI, common rail base engine is TA1
6-cyl. turbo die. e. 2.5 L/120 kW V6 24Vfuel distributor injection pump base engine is T5T/T1K
6-cyl. turbo dies. eng. 3.0 L/147 kW 24VV6 TDI, common rail base engine is T41
6-cyl. turbo dies. eng. 2.7 L/125 kW 24VV6 TDI, common rail base engine is TA1
8-cyl. turbo dies. eng. 4.2 L/230 kW 32Vcommon rail base engine is TB1
6-cyl. turbo dies. eng. 3.0 L/165 kW 24VV6 TDI, common rail base engine is T41
4-cylinder gasoline engine 1.6 L/73 kW w/ catalytic conv., US 83 (ethanol fuel)
4-cylinder gasoline engine 1.6 L/67 kW multi-point injection, US 83
4-cylinder gasoline engine 1.8 L/92 kW with multi-point injection, EU 3D base engine is T6W
4-cylinder gasoline engine 1.6 L/74 kW with multi-point injection, EU 3D base engine is T6U
4-cyl. turbo diesel engine 2.0 L/100 kW (TDI) with pump-jet injection system base engine is T1E
4-cyl. gasoline engine 1.8 L/110 kW 20V turbo base engine is T8C
4-cyl. gasoline engine 1.8 L/132 kW 20V turbo base engine is T8C
6-cyl. gasoline eng. 3.2 L/184 kW 24V fuel-stratified injection base engine is T14
6-cyl. gasoline engine 3.0 L/162 kW 30V V6 base engine is T15
4-cyl. gasoline engine 1.8 L/110 kW 20V turbo, EU 3D base engine is T8C
4-cyl. gasoline engine 1.8 L/132 kW 20V turbo, US 83 base engine is T8C
4-cyl. gasoline engine 2.0 L/147 kW 16V turbo FSI, homogeneous base engine is T59/T61
4-cyl. turbo gasol. eng. 1.8 L/165 kW 20V, US 83 base engine is T6B
4-cylinder gasoline engine 1.6 L/64 kW EU 2 base engine is T19
4-cylinder gasoline engine 2.0 L/88 kW MVEG 2 base engine is T10
4-cylinder gasoline engine 2.0 L/88 kW US 83 base engine is T10
4-cyl. gasoline engine 1.8 L/96 kW 16V fuel-stratified injection base engine is T49/T57
4-cyl. gasoline engine 2.0 L/110 kW 16V fuel-stratified injection base engine is T58/T17
4-cyl. gasoline engine 2.0 L/132 kW 16V turbo FSI, homogeneous base engine is T61
4-cyl. gasoline engine 2.0 L/100 kW 16V multi-point injection base engine is T61/T67
4-cyl. gasoline engine 2.0 L/132 kW 16V turbo base engine is T68
4-cyl. gasoline engine 2.0 L/121 kW 16V fuel-stratified injection base engine is T76
4-cylinder gasoline engine 1.8 L/73 kW with catalytic converter, US 83 (gasoline fuel)
4-cyl. gasoline engine 2.0 L/110 kW 16V fuel-stratified injection, homogeneous base engine is T58
4-cyl. turbo diesel eng. 1.9 L/110 kW TDI with pump-jet injection system, EU 3base engine is T20
6-cyl. gasoline eng. 3.6 L/206 kW 24V VR6, FSI, homogeneous base engine is T05/TA0/TH0
4-cyl. gasoline engine 1.0 L/51 kW 16V FTP 75 base engine is T9Q
4-cyl. turbo gas. eng. 1.0 L/82 kW 16V US 83 base engine is T22
4-cyl. turbo diesel engine 1.9 L/96 kW TDI with pump-jet injection system, EU 3base engine is T9J/TG0
4-cylinder gasoline engine 1.4 L/44 kW multi-point injection, D4 base engine is T8H
4-cylinder gasoline engine 1.0 L/37 kW multi-point injection, D4 base engine is T8F
4-cylinder gas. engine 1.6 L/77 kW 16V with multi-point injection, EU 4/D4 base engine is T27/TL0
3-cylinder gasoline engine 1.0 L/37 kW base engine is T28
4-cyl. turbo diesel engine 1.9 L/63 kW pump-jet injection system base engine is T21
4-cyl. turbo diesel engine 1.9 L/77 kW pump-jet injection system base engine is T21
4-cyl. gasoline engine 1.4 L/63 kW 16V fuel-stratified injection base engine is T74
4-cyl. gasoline engine 1.6 L/75 kW 16V fuel-stratified injection base engine is T75
4-cyl. gasoline engine 2.0 L/177 kW 16V turbo FSI, homogeneous base engine is TA2
4-cylinder gasoline engine 2.0 L/88 kW base engine is TB2
4-cylinder gasoline engine 1.0 L/53 kW E00, with multi-point injection base engine is TB0
4-cylinder gasoline engine 1.6 L/68 kW with multi-point injection base engine is TD2
12-cyl. gas. eng. 6.0 L/316 kW WR12 48V Motronic base engine is T1H
4-cyl. gasoline engine 2.0 L/132 kW 16V fuel-stratified injection, homogeneous base engine is TA3
4-cyl. turbo diesel engine 1.9 L/77 kW TDI with pump-jet injection system base engine is T71
4-cyl. turbo diesel 2.0 L/103 kW 16V TDIwith pump-jet injection system base engine is T9G/TB3
4-cylinder gasoline engine 2.0 L/82 kW with catalytic converter, US 83
4-cylinder gasoline engine 1.8 L/67 kW
4-cylinder gasoline engine 1.0 L/37 kW MVEG 2 base engine is T4F
3-cylinder diesel engine 1.4 L/66 kW TDIand pump-jet injection system base engine is T60
5-cyl. gasoline engine 2.5 L/110 kW 20V (in-line) base engine is T8K
4-cylinder engine 2.0 L/85 kW bivalent (natural gas) base engine is T11
4-cylinder gasoline engine 1.4 L/55 kW intake manifold injection base engine is TE0
4-cylinder gasoline engine 1.0 L/53 kW intake manifold injection base engine is T97
4-cyl. gasoline engine 1.6 L/85 kW 16V fuel-stratified injection, homogeneous base engine is T72
4-cyl. gasoline engine 1.4 L/66 kW 16V fuel-stratified injection base engine is T74
4-cylinder gasoline engine 1.8 L/74 kW BOSCH Motronic, BIFUEL base engine is TG2
4-cyl. gasoline engine 1.4 L/125 kW 16V TSI with compressor and turbocharger base engine is TF0
4-cylinder gasoline engine 1.4 L/61 kW intake manifold injection base engine is TE0
4-cylinder gasoline engine 2.0 L/114 kW with catalytic converter, US 83
8-cylinder gasoline engine 4.2 L/175 kW EU 3D, camshaft adjustm. w/o cyl. cutoutbase engine is T7S
6-cyl. gasoline engine 2.4 L/125 kW 30V base engine is: T7T
6-cyl. gasoline eng. 2.8 L/154 kW 24V V6fuel-stratified injection base engine is T44
6-cyl. gasoline engine 2.4 L/125 kW 24V base engine is T45
8-cyl. gasoline engine 4.2 L/253 kW 40V multi-point injection base engine is T79
8-cyl. gasoline eng. 6.8 L/336 kW 16V V8biturbo
8-cyl. gasoline eng. 6.8 L/298 kW 16V V8biturbo
10-cyl. gasoline eng. 5.0 L/330 kW 40V V10 FSI base engine is T8E
10-cyl. gasoline eng. 5.0 L/309 kW 40V V10 FSI base engine is T8E
5-cyl. turbo diesel eng. 2.5 L/65 kW TDIcommon rail base engine is TA7
5-cyl. turbo diesel eng. 2.5 L/80 kW TDIcommon rail base engine is TA7
5-cyl. turbo diesel 2.5 L/100 kW TDI common rail base engine is TC7
5-cyl. turbo diesel 2.5 L/120 kW TDI common rail base engine is TC7
8-cyl. gasoline engine 4.2 L/235 kW 40V multi-point injection, V8 base engine is T79
5-cyl. diesel engine 2.5 L/120 kW pump-jet injection system base engine is T03/T86
4-cylinder gasoline engine 1.9 L/47 kW with catalytic converter
6-cyl. gasoline eng. 3.2 L/169 kW 24V VR6 base engine is T31
6-cyl. gasoline eng. 2.8 L/150 kW 24V VR6 base engine is T30/T9T
6-cyl. gasoline eng. 2.8 L/257 kW 24V VR6 EU 4, biturbo base engine is T32
6-cyl. gas. engine 3.2 L/184 kW 24V VR6 base engine is T33/T3D/T36
6-cyl. gasoline eng. 3.2 L/165 kW 24V VR6 base engine is T34
6-cyl. gasoline eng. 3.2 L/184 kW 24V VR6 fuel-stratified injection base engine is T35
6-cylinder gasoline engine 3.0 L/160 kW 30V V6 base engine is T15
4-cyl. gasoline engine 2.0 L/191 kW 20V turbo base engine is T48
4-cyl. gasoline engine 1.8 L/136 kW 20V turbo base engine is T8C
4-cyl. gasoline engine 1.8 L/180 kW 20V turbo base engine is T6B
4-cyl. gasoline engine 1.8 L/140 kW 20V turbo base engine is T0L
4-cyl. gasoline engine 1.6 L/77 kW plus with multi-point injection base engine is T2U
4-cyl. gasoline engine 1.8 L/120 kW 20V turbo base engine is T0L/TF2
4-cyl. gasoline engine 1.8 L/118 kW 16V turbo FSI, homogeneous base engine is TH2
6-cyl. diesel engine 5.9 L/260 PS 24V (Cummins), TDI fuel distributor injection pump, EPA 02
4-cyl. turbo dies. eng. 3.9 L/170 PS 16V(Cummins) TDI common rail, EPA 98
4-cylinder gasoline engine 1.6 L/72 kW multi-point injection base engine is T1J
4-cyl. turbo diesel engine 1.9 L/81 kW TDI with pump-jet injection system base engine is TJ0
4-cylinder gasoline engine 1.8 L/76 kW with catalytic converter, US 83
6-cyl. turbo diesel eng. 8.3 L/300 PS TDI Euro 2
6-cyl. turbo diesel eng. 8.3 L/290 PS TDI Euro 1
6-cyl. turbo diesel eng. 5.9 L/212 PS TDI (Cummins) pump-jet injection system,Euro 2
6-cyl. turbo diesel eng. 5.9 L/212 PS TDI with distributor injection pump, Euro 2
6-cyl. turbo diesel eng. 8.3 L/250 PS TDI Euro 1
6-cyl. turbo diesel eng. 8.3 L/218 PS TDI Euro 2
4-cylinder diesel engine 4.3 L/95 PS Euro 1
4-cyl. turbo diesel eng. 4.3 L/120 PS TDI Euro 2
4-cyl. turbo diesel eng. 4.3 L/145 PS TDI Euro 2
4-cylinder diesel engine 6.5 L/240 PS Euro 2
6-cylinder diesel engine 6.5 L/180 PS Euro 2
6-cylinder diesel engine 6.5 L/206 PS Euro 2
6-cylinder diesel engine 5.9 L/160 PS Euro 2
6-cyl. diesel engine 5.9 L/250 PS 24V (Cummins) common rail, Euro 3
4-cylinder diesel eng. 3.9 L/145 PS 16V (Cummins) common rail, Euro 3
6-cyl. turbo diesel engine 5.9 L/185 PS 24V (Cummins), TDI fuel distributor injection pump, EPA 02
6-cyl. diesel engine 5.9 L/247 PS 24V (Cummins) common rail, EPA 02
6-cyl. diesel engine 5.9 L/190 PS 12V (Cummins) common rail, Euro 2
6-cyl. diesel engine 8.3 L/256 PS 12V (Cummins) Euro 2
4-cyl. turbo dies. eng. 3.9 L/170 PS 16V(Cummins) TDI common rail, Euro 3
4-cyl. diesel eng. 4.8 L/143 PS 16V MWM common rail with turbocharger, Euro 3
4-cyl. diesel eng. 4.8 L/207 PS 16V MWM common rail with turbocharger, Euro 3
4-cylinder gasoline engine 2.0 L/84 kW with catalytic converter, US 83
6-cyl. diesel eng. 7.2 L/290 PS 16V MWM common rail with turbocharger, Euro 3
4-cylinder diesel engine 1.9 L/47 kW SDI
5-cylinder diesel engine 2.5 L/55 kW SDI
5-cyl. turbo diesel engine 2.5 L/88 kW
5-cyl. turbo diesel engine 2.5 L/111 kW
5-cylinder diesel engine 2.5 L/40 kW SDI
5-cyl. turbo diesel engine 2.5 L/74 kW
6-cyl. gas. eng. 3.2 L/177 kW 24V VR6 base engine is T31/T36/T3D
8-cyl. gasoline engine 4.5 L/250 kW V8 base engine is T91; for PORSCHE
8-cyl. gasoline engine 4.5 L/330 kW V8 biturbo base engine is T90; for PORSCHE
5-cyl. turbo diesel engine 2.5 L/108 kW
4-cylinder diesel engine 1.9 L/37 kW SDI
4-cylinder diesel engine 1.9 L/29 kW SDI
6-cyl. turbo dies. eng. 8.9 L/345 PS (Cummins) TDI common rail, Euro 3
4-cyl. diesel eng. 4.8 L/180 PS MWM common rail with turbocharger, Euro 3
6-cyl. turbo dies. eng. 3.0 L/120 PS 16V(International) TDI common rail, Euro 3
6-cyl. turbo dies. eng. 3.0 L/140 PS 16V(International) TDI common rail, Euro 3
4-cylinder gasoline engine 1.6 L/43 kW with catalytic converter
6-cyl. diesel eng. 7.2 L/260 PS 16V MWM common rail with turbocharger, Euro 3
