Oggi suona il mio amico sda :elio) :elio)
E....
TA DA :Ball) :Ball)
Boston Pro 10.5LF 2Ohm
Caratteristiche
Nominal Size 10" (25cm)
Mounting Cutout Diameter 9-1/8" (232mm)
Mounting Depth—Front Mounted 4-3/4" (121mm)
Mounting Depth—Rear Mounted 5" (127mm)
Recommended Amplifier Power 50–1100 watts
Nominal Impedance 2W/4W
Recommended Enclosure Sizes:
Gross Internal Volume0.5ft3 (14 liters)
-3dB Down Point (In-car)20Hz
System "Q" (2W/4W) 0.8/0.95
Recommended Enclosure Dimensions:
Height (Internal) 7.5" (19cm)
Width (Internal) 11.0" (28cm)
Depth (Internal) 11.0" (28cm)
Theile/Small Parameters: 10.5LF(2W)
Resonant Frequency (Fs) 33Hz
Equivalent Volume (Vas) 35 liters
1.24ft3
Total Q (Qts) 0.44
Electrical Q (Qes) 0.47
Mechanical Q (Qms) 8.0
Compliance (Cms) 255mm/N
Moving Mass (Mms) 90g
Cone Area (Sd) 315cm2
Voice Coil Diameter 51mm
Voice Coil DCR (Re) 1.6W
Voice Coil Inductance @ 1kHz (Le) 0.40mH
Linear Excursion—One Way (Xmax) 8.5mm
Peak-to-Peak Max. Excursion 35mm
Reference Efficiency (ho) 0.26
Adesso devo crearmi una cassa adatta.
Che dite cassa chiusa o reflex?
La Boston consigla cassa chiusa da 14L se ho capito bene o no??
Toc Toc Rapidello Non è che hai voglia di fare 2 calcolini per me.. :fluffle)
Tieni conto che sarà tagliato attivo a 63Hz 18db
E....
TA DA :Ball) :Ball)
Caratteristiche
1.24ft3
Total Q (Qts) 0.44
