Ciao ragazzi,vorrei comprare una registratore dvd con Hdd per mandare in pensione tutto l'ambaradan che ho a casa..quali caratteristiche devo cercare in un apparecchio del genere?tipo se l'Hd deve essere come quelli dei pc normali (nel caso uno lo voglia cambiare o sostituire) "estraibile" ,su quali supporti registrare (dvd + o - r),facciamo un esempio,copio e incollo le caratteristiche di un apparecchio
Built-in 3.5-inch 250GB hard disk for recording
Recording supported: DVD-R/RW disc, DVD+R/RW disc and hard disk
Playback discs supported: DVD+R/RW, DVD Video, DVD-R/RW, VCD, SVCD, HDCD, CD-R/RW, MP3, JPEG, Kodak Picture CD
Hi-recording program from TV, satellite or cable directly to DVD-R/RW, DVD+R/RW or HDD
MPEG-4/DivX (optional)
Nicam dual languages (optional)
USB/HDMI jack (optional)
Automatic TV channel scanning and memorizing
Live and timed recording
Continuous recording function and supports auto-searching free space for recording
Automatic index creation of all recordings
Easy editing for video content and trimming home videos
Recording modes supported: HQ, SP, EP and SLP
Built-in DV link (IEEE1394)
Product Certifications:
Certificate Standard:CE
Oppure questo..
Inputs and output
SCART R-G-B video input/output
S-video input
USB compatible
i-Link (IEEE1394) Digital Video Input
Video recording
5 recording modes (60 - 360 minutes settings)
Wide-Screen signaling recording
Recording & Editing Control
One touch recording
VPS / PDC for smart recording
Show View / Video Plus+ for easy recording
TV Standard
Scan Frequency :
PAL/SECAM - 50Hz
NTSC - 60Hz
Number of lines :
PAL/SECAM - 625
NTSC - 525
Internal Tuner for PAL/SECAM
Front Connection
i-Link DV : IEEE 1394 4-pin
Video Input : Cinch (yellow)
Audio Left/Right Input : Cinch (white/red)
Rear Connection
SCART 1 CVBS, S-Video/RGB output
SCART 2 CVBS, S-Video Input
S-Video Output : Hosiden 4-pin
Video Output : Cinch (yellow)
Audio L/R Output : Cinch (white/red)
Digital Audio Output : Coaxial
PCM : IEC958
MPEG, AC-3, DTS : IEC1937
RF Antenna In : Coaxial 75 ohms
RF TV Output : Coaxial 75 ohms
On-Screen Display - Languages
English, French, German, Dutch, Spanish, Italian, Swedish, Danish, Norwegian, Finnish, Portuguese
Programming
Number of events : 6; Daily/Weekly; Monday to Friday
Programming mode : OTR
Record control and Timer programming : Manual / Video Plus / VPS
Recording Functions
One-Touch Record (OTR)
Append / Divide / Erase
Automatic / Manual Chapter Marker insertion
Disc write protection
Index Picture Screen for instant content overview
Power Supply
Power inlet : 220-240V 50/60 Hz
Power consumption : Operation : 30W, Low-power (standby) : 3W
Dimensions : 430(W) x 370(D) x 55(H)mm
Net Weight Approx. 4.15kg
40 to 250GB HDD selectable
Spero di non aver creato un post confusionario...
Oppure questo..
Inputs and output
S-video input
USB compatible
Video recording
One touch recording
TV Standard
Scan Frequency :
PAL/SECAM - 50Hz
NTSC - 60Hz
Number of lines :
PAL/SECAM - 625
NTSC - 525
Front Connection
Rear Connection
PCM : IEC958
Programming
Recording Functions
Power Supply
